Originally Posted By: Panzerman
Originally Posted By: Hokiefyd
The biggest issue (that the report misses) isn't the environmental part, but the line-clogging nature of FOG (Fats, Oils, Greases). FOG is responsible for countless sanitary sewer overflows when it's poured down a drain and later congeals. Hopefully, for the integrity of the storm sewer system in that area, there's an outfall close by where the cooking oil will end up back out in the open.
This shouldn't have happened, but honestly, there are worse things for the environment than used cooking oil.
First of all the Storm system and a sanitary system aren't even remotely the same animal. Storm systems are for rain water/branches,leaves and all kind of debris. Sanitary system, well we all know what that is and its much smaller. They never interlink and a sanitary system leads to a waste water treatment plant. A storm system leads to a water retention area where it perks down into the ground. That being said and explained. All this stuff about oil being super harmful to the environment is propelled by a younger generation that really don't know but figure. I can tell you when I was younger my father would have me oil down the dirt alley by our house with used motor oil, gallons of it and the city boro would come out with a oil tanker and open the valves and oil the entire fairgrounds which was all dirt. It never killed the trees or even the grass. I ve heard all the one drop of oil contaminates a zillion gallon. Truth is the ground is a pretty good filter till it gets down and isn't oil natural. I can guarantee you that there are a lot worse things in a storm system than cooking oil. I once watched a new truck dealership drain a radiator of a tri-axle in a storm drain. Believe me that cooking oil wont hurt a thing. Its just new generation environuts freaking out over stuff they don't know about.
Cities in the Northeast are spending millions rebuilding their sewer systems to separate the storm drains from the sanitary sewers. In some areas, downspouts are tied into the combination systems and to find them thick white smoke is blown INTO the drain lines. When the smoke pours out of the gutters they've found a live one.
