I have a 2008 Porsche C2S with 44,000 miles on it (bone stock car). I change my oil every 5000 miles with Mobil 1 0/40W. On my last Blackstone analysis, they said my sodium was high (69) versus the previous two reports of 6 and 7 respectively. Potassium is right in line with where it should be as is all other tests they conducted. They said the high sodium might be from an additive or coolant leak. When I inquired again, they said since the potassium was very low, it is most likely from additive. Thing is, I've added nothing to my oil. Appreciate thoughts. BTW, oil level and coolant level are consistently right on the mark - neither gaining or losing either. Thanks......
