Originally Posted By: Carbon12
Is it just me or does it seem like most engines now have a higher sump capacity than say even 10 years ago? It seems like V8s are holding 8 or 9 qts now. My 98 silverado with a 5.7L only held 5qts. Wouldn't the higher volume result in lower oil temps and thus higher viscosity? Maybe xW-20 no thinner under actual conditions of use?
A bigger sump effects the time it takes for the oil to reach operating temperature much more than it does the ultimate running temp.
Larger sumps would seem to be a reaction to the 'Merican public's aversion to use of the dipstick. More oil in the sump, especially with extended OCIs, means it is less likely to run too low before the next change.
