Originally Posted By: ToadU
Check the hydra boost unit located behind the master cylinder. GMs infamous hydro boost could be the cause. Cheapest place is roackauto for a new one.
After shutting off the engine, wait five minutes and try pumpng the brakes, you should get atleast a few power assisted pumps. If not check the booster's vacuume check valve and the booster itself for leaks.
Also, if you pressed the pedal down to the floor while bleeding, the master cylinder could be internally bypassing fluid and will need replacement.
