Originally Posted By: Brybo86
when i was younger i recall my dad with bad ears used to run straight water in our mazda minivan and I clearly remember pulling into the driveway after a 20 min ride, turning off the car and then listening to the water boiling in the overflow tank...
Yeah the tank isn't pressurized, so when it got past the radiator cap into the hose going to the tank it boiled. If you could somehow "see inside" you'd see it behaving. But if you pulled the cap it would flash boil and scald you good.
I've run straight water, changing it every day for a week.
The simple green is a bit odd, I use cascade dish detergent to get oil out. Even that isn't "great" as it's got bleach, but it didn't wreck anything.
