Wow, you guys are awesome....I have to admit that I am not a numbers guy, and my sense of time is not the best, so apologize if my accuracy is off, if it is that important.
So in summary, yes, I have always had an issue burning a quart or so every 1500 miles.
I was a little surprised when I recently checked my oil and there was none on the dipstick, so I added 1 quart at a time and it took 3+ quarts to bring it back up...did not keep track of the miles. Did about 500 miles of driving and am down a quart again.
With all the feedback, I have ordered a new PCV valve and hose assembly from Ford and when I replace, I will switch my oil over to the OW-30, and monitor and see what the new results are.
This should help me identify if it was a PCV system malfunction, or if it is possible that the spark plug repair caused more of an issue that made the oil consumption get worse, in which case, I guess I feed it more oil, or get into some deeper rebuilding.
I do see the confusion, that if it was a spark plug issue, so many miles ago, why would I not have had to put 20 quarts of oil in since then.
Vehicle seems to run very well, just a little occassional drop, then back up in RPM's at red lights when the temperature is a little cooler. Only other issue I have experienced is an occassional stall, only when my trailer is hooked up, backing up then sudden stop with less than a 1/2 tank of gas. I assumed this was a fuel tank related problem, but it happens so rarely, I don't give it much thought.
