Been using the coil rites for just over 4 years on my Ram. They work great... when they work. The driver side bag holds air quite well year round and the pass side begins to deflate around that -20C mark and around -30 it cant hold air for more than an hour. This spring I took the valve off and re-cut the end of the plastic air hose to ensure it was square. Now the thing leaks all the time. I tried using some white pipe dope but I cant quite get it to seal. I cant cut anymore line as there is not much more to give. As well the line has been exposed to the elements for those 4 years and would not seal anyways. The valve has a one way slip fitting and an O-ring that seals on the outside of the air line.
Any recommendations?
I love having the air bags as they are amazing during heavy tows and easy to deflate for everyday driving.
