Originally Posted By: Trav
Glad you got it sorted. The stuff works great and its cheap enough. Use the rest to hold gaskets in place for gasket assembly or stick loose weather stripping.
I use it on gaskets all the time, like some thermostat housings that use o rings and are vertical, just a little on the sides of the o ring will keep it in place while you get the neck on.
It can make life real easy, its worth having a small tube in the toolbox, it has a 1001 uses.
BTW The stuff is resistant to vibration, oil, gasoline, coolants and most chemicals.
Nice tip Trav! I need to pick up some for a few of those "1001 uses" on my list. Gotta love 3M. I've never used anything of theirs I didn't like.
