There is the pressure on the door placard,
and there is the pressure listed on the sidewall of the tire...
Door placard is for maximum ride comfort,
pressure on the sidewall is for maximum inflation...
My original tires on my Saturn were 35 PSI max, Q rated
and 185/65R15...
Current is H rated 205/60R15, 52 PSI max...
I run 45-47 PSI...
Higher PSI than the door placard, without exceeding max pressure listed on the tire, while it gives a harsher ride, also yields better wear and fuel economy...
