Originally Posted By: JHZR2
Originally Posted By: Pop_Rivit
I switched all of my vehicles tires over to a semi-nitrogen blend. I liked the results so much that I also use the semi-nitrogen blend all of my tractor tires, lawn equipment, and even the tires on my air compressor. I found that the performance is outstanding and I can get the blend at a much better price point than 100% nitrogen. I've even gone so far as to invest in a system from Ingersoll Rand that compresses the blend and makes it ready for use in tires.
The semi-nitrogen blend is roughly 78% nitrogen, 20% oxygen, and 5 or 6 other additives.
Ooh do tell us more! Where can I get this wonderful stuff? I wonder if the additives need to be boosted up?
Oh-absolutely. I have a 300 can stash of Marvel Mystery Air that I bought at AirMart on rollback and I use it on a regular basis. I also use a product called AirRX that does a great job of removing slime from older tires. I've never used it, but Slick N50 has a YouTube video that shows a car on a lift, and when it's running and in gear the tires will rotate for hours with absolutely no air in them!
But if you really want the best, just look for a company called AmsAir. They have a 4 ball air test that proves their air is superior to all the other air on the market.
