98 Expedition, 5.4 4x4 188K miles
The bearings in my idler pulley seem to be dry and noisy, (can hear the bearings rolling when spinning on center axis) but no noticeable play.
The dealer bearing is 60.00, aftermarkets are about 20-30.00. The aftermarket choices seem to be Dayco, Dorman and Litens. Dorman has lifetime warranty, Dayco has 1 year.
Should I spend the extra money for the OEM pulley, or are the aftermarket ones equal or better than OEM?
Also, dealer sells tensioner assembly for 90.00. Advanced has Carquest and Litens for about 45.00 (Looking at the Litens image, the bearing is stamped made in China). Not sure about the carquest. Do these tensioners have a life expectency? Should I change it while I am in there or maybe just replace the tensioner pully? I haven't pulled it yet to see how those bearings are.
