Hi all,
I've been running an NMMA Approved 25w40 in my Volvo Penta 5.7GL (flat tappet cam) and would prefer to be using a similar viscosity oil, with a better ZDDP additive pack.
My boat is kept on a trailer and thoroughly flushed with fresh water after each use in both salt and fresh water.
Does the additive pack in the NMMA oil have a tackier additive that better resists internal corrosion when compared to a conventional oil?
Will the NMMA oil provide better protection over a 3 month 'lay up' period?
A local blender has a POA/ Ester based 15w50 that contains no VII and has copious amounts of zinc/ boron, that I'd much prefer to use.
Am I running the gauntlet by using non 'marine' products in a carburetted, flat tappet boat in salt water?
Some tech info on the NMMA Oil:
http://www.penriteoil.com.au/products.php?id_categ=8&id_subcateg=200&id_products=368
Tech info on the PAO/ Ester 15w50:
http://www.penriteoil.com.au/products.php?id_categ=1&id_brand=3&id_products=278
Any technical advice or support is appreciated!
Cheers - Daz.
Cheers - Daz.
