Well it took about 30 hours as we had some trouble with the valve spring tool and getting the roller rocker assembly off. Also, after the first time getting everything back together... The timing was out by 1 sprocket tooth on the crank sprocket. We were trying to be so careful to keep tension on the timimg chain, but we must have let off for a moment and the chain shifted down below on the crank. Sp that added an extra 10 hours or so. I also adjusted the valve timing according to the service manual, but it definately sounds too loose, so i am going to open it up again soon and re-adjust again. Knowing what i know now, i would have taken about 12 hours all said and done.
Yes, this was my first time working on an engine, internally. I feel much more confident now.
Oh, I also was very maticulous on bolt torque specs and tightening sequences. Very important, imo.
Symptoms were blue smoke on start up after sitting for at least a few hours. There was also loud rapping noise from carbon buildup that is NOW GONE. Very happy with the results. Scary thing is though, I went on a 1800km road trip to Vancouver the day after I was done.
