Can someone explain why you want to heat up the transmissions fluid in the car when you are changing it? I understand the need to get the engine up to operating temperature when you are testing the level of the ATF, but not when you are changing it.
For instance, if your car is at ambient temperature, and your new ATF (in the bottle/jug/whathaveyou) is at ambient temperature, and it is important to replace the same amount of fluid that you drain out, why would you want to heat up the fluid inside of the car before adding in the new fluid (thus making its characteristics different from your new fluid)? Wouldn't that throw off your measurements when comparing what was removed to what is being added?
Is there something that I am missing? I recently did a simple drain and refill on a Civic that was cold (ambient) and after a good long test drive on the highway to heat it up the ATF measurement was exactly where it should be. But I keep reading that you should heat up the liquid first when changing it.
