Originally Posted By: BRader
Hello all, new here. My 01 4runner is due for its 5000 OC. I bought it 5 years ago with 155,000 from the 1st owner. I have been using the Toyota "certified" oil and OEM filter since I have owned it. No leaks or consumption but I am curious as to if a HM, HMS or blend should be in order since I am coming up on 200,000. Also, should I cut back to 3000 mile OCIs or remain at 5000 OCIs? My 4runner is all I have and I need it to last.
Thanks in advance for suggestions.
My '00 4runner (V6 manual) has had a steady diet of Mobil 1. At 248k, it has no leaks, and has yet to use any measurable oil. Most of that milage, I have used vanilla 5W/30 M1, but the last few years, it has been getting 0W/30 AFE, with no ill effects. I see no reason to put HM oil in it, until it actually loses some. Oh, and I use the same 5k OCI you are using, mainly because these days, it sits most of the summer, gets used a lot in winter, and on the occasional off road excersion the rest of the year. Annual mileage is only about 5k, these days.
