It is ok, he likes to ignore my 3,010mi failure (after the 3,700-4,000mi failure) with PureOne and a high bypass spec. Back-to-back filter failures. One filter failure is bad, but plausible... two is a serious problem. Shame on you, shame on me, never again.
Here is the trick, Purolator filters fail. You don't see the same failure for cheap jobbers, so why does the middle/middleupper-priced (as well as the tearolator jobbers) fail?
