This is a serious question. My Audi requires a hths of 3.5 or greater. For instance some of the oils in that category have a zinc level and phosphorous of 700-1000ppm. Zddp is suppose to prevent wear. I've been pondering this question and want some expert advice. If you get an oil with an hths of 3.4 (a tad thinner than spec calls for) BUT has a zddp level of 1200 ppm or more (higher anti wear additives) does that kind of cancel out the possibility of excess wear with the "lower" hths? It has been puzzling me because for the life of me I can't come up with a logical answer. Thinner oil by a tiny amount but a noticeable amount more anti wear additives SHOULDNT cause anymore wear than a proper hths with lower additives should it? What about with a turbo application?
