Its been my experience fuel is not like water, once its there you cant rid it , even riding 5 hours straight.
The majority of motorcycles fuel dilute some what, but with your uoa , I'd step down to 1500 miles.
However that's only the second oil dump, and normally until you get past 5,000 or 6,000 miles , then you'll probably see a little improvement, and then extend out to 2,000 miles, if the numbers show its allowable.
your basically triple what I want to see metal count wise in an oil change. Clutch fibres like clean oil.
also there's nothing special about that 10w60 is doing that a much cheaper 20w50 will.
