ls1mike
$50 Site Donor 2024
I just replaced the one on my truck 38,000 miles and 13 years old. Reason being is the gasket to the block was leaking! It sits too long. Pump was fine, but since I was in there I purchased a brand new AC/Delco unit. 6 bolts hold the pump to the block.
Of all the cars I have had, I can only recall two failures. One on my 02 TDi Jetta and After I did the cam install on the Trans Am the pump failed. I think it may have been because it got dropped from the lift...
