Removed, repaired and reinstalled my pedal assembly then I replaced the distributor cap and rotor on my 91 Honda Civic Hatchback Si. I started my car and I immediately noticed that the RPM needle does NOT work.
Took my car for a drive and it ran smooth.
I didn't dare go on the freeway for fear of getting stranded. My triple A (AAA) card already has been used 4 times (4 tows) for the year.
Observations:
I noticed a small cut ( disconnected) wire next to the other disconnected wire that goes to a thermo switch that activates the temp gauge. I looked around to see where the small wire hooks up to but I could not find anything.
Something must be there and I will go ahead and look some more tomorrow.
Could this wire, located under the distributor, be the one causing the problem.
I have 2 other distributors that I will be swapping to see if the RPM needles comes back and moves.
Please advise
Observations:
Please advise
