Originally Posted By: linksep
Originally Posted By: Trav
The main reason for the apparent higher failure rate is a lot of the time people would do a "flush" as a last ditch effort to fix a sick unit. It would have died anyway.
I agree with this somewhat, however a buddy of mine that worked at a trans shop for several years says flush/exchange (without filter) is what kills trannies most often because the fresh detergents in flush/exchange dislodges all the gunk and plugs the filter causing low hydraulic pressure and slipping clutches in his opinion.
I follow his advise and disconnect the cooler, run the engine to pump out ~2 qts of fluid (so the pan doesn't drip), drop the pan, clean the pan and magnet, replace the filter, reassemble, refill the pan through the dipstick tube, then use the trans pump to exchange the remaining fluid using the two-bucket method until it runs clean through the (clear) hose on the pressure side of the cooler lines. That's for a trans that has unknown history or known neglect. Regular filter/top-off (partial change) is suitable for a trans with a good known service history.
New filter and full fluid exchange is best, new filter and 3-6 quarts is second best, anything that doesn't involve a new filter is dangerous in his opinion.
I agree with him 100% and thats exactly what i posted earlier in this thread. On some transmissions i pump it out first then drop the pan, others with a drain plug just drain it first, get the filter changed then pop the line. Same difference, the filter still gets changed.
Originally Posted By: trav
Drop the pan, replace the filter, add the same Amount of fluid that came out then drop the return line before starting the engine.
Connect a piece of vinyl tubing to the return line and put it a gallon container. Start the engine and run it till the jug is full, add a gallon and repeat until the fluid is the same color as the fluid going in.
Fill the fluid to the lower mark, drive it till warm then check the level.
