So, many manufacturers spec using some sort of ATF as an accepted or recommend fluid for power steering systems. Some other vehicles spec actual "power steering fluid" , and other even use some "special" type of fluid such as Honda, or some of the Euro cars that call for a Ch-fluid.
I have replaced fluid in systems that used older style "power steering fluid" with ATF and never had any problems. And I think some even recommend using ATF now even in order vehicles that didn't use ATF.
So today while bored, I was on Lubegard's site looking at their products, and in the info regarding their Power Steering fluid, I cut this statement out
"Power steering fluid is not interchangeable with automatic transmission fluid (ATF) because ATF does not have the anti-wear protection or shear stability needed to protect the power steering pump."
Where does this come from? If ATF does not protect power steering pumps, why are OEM's using it?
Is this supposed to be directed for a vehxole that calls for the old style, brown/yellow power steering fluids that Chryser,GM, and others used to use in their older vehicles?
Just trying to make sure I'm not missing something here with P/S fluid and ATF.
