Use Dana 44HD open Spider Gears instead trac loc?
Germany
Hello,
is it possible to simply replace the spider gears from a Dana 44HD trac loc in a ´97 ZJ with open diff spider gears?
To specify it a little more.. using this kit instead of this one without further changes?!
Thanks and kind regards.
This is how it looks like in my case:
The red markings I made to show the defective gears to a friend.
Alright, thank you!
Would you still drive with those pieces missing in the spider gears?
Currently I'm unsure whether I should replace gears with new ones, buy a used Dana 44 (check if it's okay first) or keep on driving with those spider gears and save the money (probably for the trans viscous aka misconstruction, I hate it).
Originally Posted By: Zaedock
The ring gear looks fine. I would replace the spiders and motor on.
That's what I will do besides changing the TL plates.
A locker needs an open differential, which would cost much more.
