Have an older snapper mower - Quantum Power 4hp
Seldom used but when used, used very hard.
Having carb issues and, from reading other similar posts, it's been suggested that a replacement is better than a rebuild given the cost, time,... In those circumstances, though, the replacement carbs seem to go for about $30
From what I've found on eBay, Amazon and others, the replacement carb for this mower is approaching $60. I haven't yet found a rebuild kit but will keep looking
Briggs Engine #: 121702-3141-01
From what I can tell, replacement carb #: 494216
I'm not here very often and the grass can be very high when I get up here. And I usually just have a weekend to get things done. Also, any store is a solid 30 miles away so I try to come prepared and want to avoid having to head out for stuff if possible.
I guess, based on above, I'm leaning toward just choking on the cost of a replacement carb but can someone talk me out of it? If it were a $30 fix, it would be a no brainer
Anyone have any experience with these units and their cArbs?
Thank you
Thank you
