Both M1 and M1 Extended Performance are the same price at Amazon. Looking to buy two 5 quart jugs by the end of the month and use the M1 $12 rebate.
Vehicle is a new 2014 Ford Edge with the 3.5L regular engine (i.e.: not DI or turbo - the 2.4L is the Ecoboost). I plan to do the first oil change around 2000 miles which should be about the end of June.
After the initial oil change I plan to follow the OLM down to about 10%. Plan on using the associated Motorcraft filter.
So which oil should I buy considering they are the same price? M1 or M1EP?
