Hello everyone. I just joined been reading stuff randomly for a bit.Really been researching oil a lot lately.
I have a 2013 Ford Taurus SHO 3.5L ecoboost awd. It does have a RX catch can on the car too. The car has alsmot 20k miles on her. It sat on dealer lots for almost a year before i bought her and had higher mileage. I don't remeber the exact amount but i think it was around 600??? I changed the FF before 1500 miles with a free oil change with ford 5w30 synthetic. It has had two more oil changes running RP5w30 that i got a decent deal on. The second OCS i got my 6th quart free and pick of any filter as the included filter i believe K&N was out of stock.
They like to dirty up the PTU/transfer case really bad and it was a time for an oil change. I decided to use LM products. Didnt some basic research on them, Amsoil, Redline, and PUP and some others. But i thought i should try out one brand for everything this time.
I bought the fluids from napa and got a 20% last month with a special.
LM2038 and LM2039 USA part numbers for LM1136 Longtime High Tech 5W-30
USA TDS
https://pim.liqui-moly.de/pidoc/P003275/2039-LongtimeHighTechSAE5W-30-6.0-en.pdf
Europe version TDS
https://pim.liqui-moly.de/pidoc/P000312/1136-LongtimeHighTech5W-30-10.0-en.pdf
75w140
http://www.liqui-moly.de/liquimoly/produ...voiladb=web.nsf
75w90
usa TDS
https://pim.liqui-moly.de/pidoc/P003271/2048-FullySyntheticGearOilSAE75W-90-4.0-en.pdf
LM website with Europe specific part number
And i also bought a Napa PFL 47502 Platinum Filter
Is there any issues to using the fluids in the Ford. My one concern i have unearthed is that the motor oil is an ACEA C3 oil that is a low SAPS formula. It is API SN approved however and that is the important thing and the correct weight of 5w30.
But i have seen some research and or thoughts that the low SAPS formulas are good for DI turbo motors. To the point of limiting deposit build up on the valves and other areas.
Thank in advance for any thoughts and comments.
USA TDS
Europe version TDS
75w140
75w90
usa TDS
