I have a side job tomorrow and I'm anticipating some amount of weirdness with this one. The customer has. Taurus with discs all around they changed rear rotors and pads on drives rear only. Ever since this the brake pedal goes to the floor...... she said her boyfriend tried to use a c clamp and it wouldn't compress it so her brother went a rented the correct tool because the piston has to rotate to go in. I wonder if maybe he messed up the caliper pistons? She said they worked before messing with them just the one side was metal to metal and when they got done it just to the floor and won't get tight again. Since I imagine some weirdness. It's nice to see what others think. Maybe he damaged the caliper pistons? Or messed up slide pins? What do you guys think?
