Hi.
I currently own a Honda 125cc scooter built specifically for my country so it's not very popular. I plan on changing the engine oil and also the gearbox oil very soon as I have hit 1000km on my odometer. However, choosing the correct oil for my scooter is unbelievably complicated. Honda recommends and sells 10W30 engine oil with JASO MB qualification for my line of scooter. The quality of Honda engine oil is horrifying as they repackage cheap oil made by some local companies and call it high quality engine oil, therefore I want to find a good oil brand for my scooter.
When I do my research, some companies said explicitly that motorcycle engine oil cannot be used interchangeably with car oil, though some argues that they are pretty much the same. Some people in my country actually does not know that an oil is for a car engine or a motorcycle one, they choose the most expensive can of oil and think that the price signifies the quality. So to be sure, i steered away from car oil, and I do not have much choices left as most Oil companies produce car oil.
Then there's the JASO MB standard. Honda demanded JASO MB engine oil to be used with my line of scooter. As I understand, MB means that the oil has very low friction, suitable for dry clutch engine since wet clutch demands some levels of friction while dry clutch does not. They also say that a MB oil will cause less friction, as a result the engine of the scooter will be very well protected.
So please clarify this problem for me. Can I use car oil for my scooter,as some companies said that scooter oils have to work in more extreme conditions and car oil isn't going to cut it? And secondly, can I use scooter oils that do not have JASO MB standard, for example JASO MA, JASO MA2 and no JASO at all?
My scooter has a dry clutch, that is for sure.
Thank you for your help.
