Originally Posted By: Kuato
I'm a big fan of early oil changes also. On my new engines I like 500, 2000 and 5000 miles before going manufacturer's intervals under warranty. To me, this insures that impurities from assembly (insert discussion about engines not needing these removed, they help with break in, etc etc) are washed out and into the filter.
Originally Posted By: skyactiv
I'm thinking it's a waste of money to do an early oil and filter change.
Read this link if you dare:
http://www.mototuneusa.com/break_in_secrets.htm
While I agree with Motoman's break in recommendations, IMO making sure the rings seal doesn't affect the oil and any junk that may be flowing around in there -- the two issues are separate.
The filter catches it.
Originally Posted By: fredfactory
Originally Posted By: btanchors
...... All oil goes through the filter before it goes into the engine (unless the filter goes into bypass). So in theory, any particles present in a UOA should be so small they wouldn't affect the wear on the engine............
Since some oil filters, and especially Toyota OE oil filters, are NOT good at stopping particles smaller than 20 microns and less, and oil film thickness inside your engine ranges from zero to 50 microns depending on which engine parts and which part of the Stribeck curve you happen to be surfing on at that moment, you can see its good to get all that sub-20-micron stuff flushed out at 1,000 miles. The mode of additional wear is a cascading wear.
Well Fred. Considering there will be quite a bit of particulate being shed the oil filter is going to get saturated quickly and thereby filling all of them filtration veins up to the point they will be trapping particulate far finer than the 20 microns you mentioned.
In fact I feel that the filter is going to become extremely efficient very quickly and changing it at 1000 miles is a BAD idea simply because a new filter won't be loaded and therefore less effective of trapping all that particulate you mention.
So in reality sure you wash out everything the engine has shed at 1000 miles but at that point anything else the engines going to shed will be much smaller and a new filter may not be effective at catching it until the media loads and the filter increase in efficiency.
Op
If you want to change the oil early go ahead but leave the filter. It will be loaded and the efficiency will be much greater than a new one which means it'll trap much smaller particulate than a new one.
I run tough guards 20000 miles on all my known clean engines. Every one drives just fine when the body rots off.
Oil filters efficiency increases as the media traps particulate so the longer you leave it the better it performs until it's completely plugged and running in by-pass
Only once have I ever seen a filter so loaded that the by-pass was open when the engine was hot. It was my first car. A cutlass with a 305. I used that engine restore garbage(do not use unless engine is on last legs already) and it completely plugged the filter and eventually killed the engine.
