right headlight out on low beam then switches to left out on high also fog lamp work only one at a time opposite the illuminated headlight could it be as simple as a bulb
if you don't want to test or replace the bulbs one simple thing to do would be to switch the bulbs side to side if the problems follow the bulbs then they are bad if the problems stay where they were then you have a wiring problem it is easy to type with no capitalization or punctuation but it sure is a lot harder to read right
The wire harness runs under the battery tray. There is a ground near there also. There is a splice for the headlights under there. Open the harness, look for swelled wires, check the splices, and redo the ground.
That was the source of headlight weirdness on one of mine.
Yes, it could be as simple as BOTH bulbs, likely one is missing the low filament and one is missing the high.
