UPDATE: over the weekend I've got the old intake manifold off and the leak that I was seeing is definitely coming from the lower intake manifold gasket. The entire gasket came out in one piece except right around the water feed on the front passenger side.
The lower intake manifold also has a significant amount of pitting right around where the water feed gasket goes so I suspect that this either was the cause of the gasket failure or a resulting factor of the leak and will probably cause significant problems if I try and just put another gasket over the pitting. Do you guys know where the best place to get a new lower intake manifold is or how to fix the pitting?
I also ran a compression test on the motor before I started pulling everything apart and got between 170-190 on all 8 cylinders. Being that this was on a cold engine I'm thinking these numbers probably indicate that the lower-end is still fine correct?
Thanks!
Thanks!
