Originally Posted By: cjcride
Any special tricks to remove salt stains/crusts from the main floor/tub carpet?
Never fun removing this stuff must be an easier way.
pour on boiling water and extract with a wet/dry shop vac
while i have no experience with that exact product, anything i have tried, that was labeld as a salt remover for shoes, etc, ended up smelling like vinegar, so i would say to save the $$ and use a combo of piping Hot H20, with a quantity of white vinegar in it. i'm not giving specific ratios, as i don't have them. but that combo, with a good wet vac, and a little elbow grease should do the trick.
My searches last year pointed to a 50/50 mix of vinegar and warm water as the most suggested solution. Then blot with a towel and hit it with a shop vac or a spot bot to get out as much as possible.
I haven't tried the mix yet, as I just cannot find the time to remove the front seats and do it.
Originally Posted By: HangFire
No magic, just lots of warm water and a wet vac. You don't need to scrub much, just enough for the water to get to the salt.
I just washed up.
Used most methods suggested. Already had a bottle of commercial salt remover spray did a so-so job as usual. Lots of stiff brushing and not much salt removal.
Asked you guys and "Voila". You know the suggestions of lots of hot water did the most dissolving. I added a Tiny bit of Palmolive dish soap. Sucked it up with the Shop Vac.
Thanks Guys.
