Hi folks,
I read bitog everyday, and now I'm joining in to get some peaceful advice
One oil to rule them all : should I switch my Renault Clio MkIV, 1.2 L4 16v NA Gasoline engine (D4F740, 55kW@5500rpm, 105Nm@4250rpm), spec'ed for 30000Km OCI on 5W40 (ACEA A3) to 5W30 (ACEA C4 level C3) RN0720 oil ? Daily rpm range : 2000-3500rpm, trashing it to the redline once a gas fill-up. Average fuel cons. : 6.5L/100km.
The reason behind this : my wife drives a Renault Koleos, powered by a M9R commonrail turbodiesel engine, running on 5W30 RN0720 (ACEA C4) DPF low-saps oil... got a relatively big sump (7 liters) and changes oil every 6 months (15000Km), so I got good deals on 5W30 C4 oils (Q8 Formula R Long Life, Yacco Lube R, Repsol Elite Evolution Power 4) as long as I buy min. 24 liters at once.
So, I was thinking of reducing oils kept on the shelf at home (5W40 for one car, 5W30 DPF for another, 10W30 for the Honda CB500X and NSR 125 gearbox, the power generator, and the lawnmower, Dexron III (Q8 Auto15 ATF) as fork oil, Nissan NS-II (Q8 Auto CVT-PB, still haven't done an oil change) for the Koleos' CVT, Tecnol Bioracing 2 stroke sunflower oil for all the 2 stroke stuff (NSR, chainsaw, 4-mix grass trimmer, mistblower, small 2-stroke generator...)
tl;dr : would switching my 5W40 spec'ed petrol engine to 5W30 full syn C4 diesel oil be benefic for that engine, or should I stay to the original 5W40 full syn A3/B4 spec ?
