Replacing the tires and servicing bearings on my IH 782. One front wheel slid right off but the other is sized on the axle.
I've tried rubber and dead-blow BFH's w/ block of wood against the backside of the rim as well as hitting the inner bearing race w/ a punch...to no avail. Currently giving the inner races a good soaking of penetrating oil. Trying to avoid destroying the bearings, but that may not be possible.
Appreciate any words of wisdom or tricks... Thanks.
