Originally Posted By: Vikas
Is the degradation gradual and linear? For example, a tire with rated 50K miles, would its performance be similar at 0K miles vs at 25K miles? For example, dry braking distance; would that remain similar at 2yr/25K time as it was at 0yr/0K miles?
I find in the dry, pretty much every tire that I've had of reasonable age, gets better and better traction and more feel.
My favorite tires I had on my Neon were some sumitomo HTR200's that I took from 7-8/32 down to 4/32. They worked good for autocross, and a bit of lapping, and still had reasonable wet grip. I think they aquaplaned a bit easier, but on 55mph roads I never had an issue even with their 205 width.
Most other tires I've had, loose a lot of wet grip as they wear.
For dry autocross though, nothing feels worse than a set of all seasons at full tread depth. The corners get destroyed and the surface overheats quickly... 3/4 worn all seasons would be better, and half worn summer tires are better still.
