Originally Posted By: HTSS_TR
Originally Posted By: racer12306
I believe the 3593A also shares the thread/gasket dimensions as the 7317 and 6607. They used to be found on every Honda >10 years ago, then Honda started switching to 7317 size.
Fram 3593A is about the same size as Honda PCX-004 for S2000.
Originally Posted By: ARCOgraphite
I witness my Nissan Versa Note knocking HARD in the winter with the tiny hamster sized Chinese Nissan filter. I then put on a Honda -pcx004 and the cold oil-starved knock went away. So not all filters are good - even factory units. ESP the older Nissan with almost no clearance around the cardboard end caps for oil to flow - never mind the possibly over-treated paper. Same problems a decade ago with THAI denso Toyota garbage.
Honda PCX-004 is a very filter, it is OE filter for S2000 which has redline up to 9,000 RPM (AP1). At that high RPM it needs a good oil flow and PCX-004 can handle it without problem. As of now my local dealers want $20 for it, online is about $10. Currently I use over-sized Wix and Fram Ultra XG3593A.
If Honda wanted the larger oil filter on the S2000(which they did) I would not use the Wix.
Here is a pic of my Baldwin, Honda S2000 and a Wix for the S2000. the Wix has a lot less filter than the Honda.
If I remember right, the Wix had around 1/3 less filter medium than the Honda S2000 filter.
ROD
ROD
