so I have been changing my transfluid with every oci since I bought my bimmer. 4 changes over the last 40k. the filter was changed by the dealer, but I should of changed it at 30k interval. oh well. im doing it at 50..
anyways Im just curious as to if you guys think I should do a non powered flush before I change the filter? even with a 5 quart drain and fill every 10k(roughly) the fluid still comes out dark brown every single time i change it. I attribute most of this to the dirty fluid already in the system, but just seems like after 4 fills it would of cleaned up, and 10k is that really enough to turn the fluid brown? maybe. idk.
anyways. what do you guys think? bucket flush from the cooling lines before then filter change, or just change the filter and refill?
