4.2 Deposit Control Additive Requirements. The deposit control additive used to meet the performance Standards described in 4.3 shall meet the substantially similar definition under Section 211(f) of the Clean Air Act. Also, the additive shall be certified to have met the minimum deposit control requirements established by the U.S. Environmental Protection Agency (EPA) in 40 CFR Part 80. Lastly, the additive shall be registered with the EPA in accordance with 40 CFR Part 79.
and:
5.1 Submission of Test Results. A fuel company desiring TOP TIER Detergent Gasoline status shall forward the test results issued by the Independent Laboratory ("Test Results") to the following address:
Jill Cummings
GM Powertrain Fuels & Lubricants
3300 General Motors Road
Bldg. 42A
Milford, MI 48380-3726
Although cutting and pasting an enitre procedural document may have padded out your post, what you've posted undermines any claims for the superiority of top-tier fuel.
In short, 4.2 tells us that the fuel need only meet the minimum additive standards established by EPA while 4.3 details how to measure the test results.
Has anyone here ever experienced a stuck valve on a cold start?
Finally, 5.1 tells us that GM controls the certification process, which seems less than confidence inspiring.
What you've posted makes the whole top-tier thing seem even more bogus.
I suspect that almost all gasoline sold in this country would qualify as top-tier for any brand willing to pay for the testing.
Deposits just aren't much of an issue for any normally operated FI engine, and no fuel can help in controlling valve deposits on a DI engine, unless the maker cheats and injects a little fuel upstream of the intake valves, as is the case with some DI implementations.
If you want to mix oils with wild abandon and think that there are no concerns asociated with doing so, it's your engine and you live in a climate where it probably won't cause any harm.
For six months out of the year here, anything that might compromise the cold performance of the engine oil is of real concern.
