Has anyone ever had the displeasure of changing an air filter in an early 2000s Ford Focus Zetec? I got two of the bolts to come off without trouble, but the third one would just sit and spin in place. The engineers at Ford had the brilliant idea to make the connecting nut completely round with no edges to put a socket around to keep the entire bolt from spinning in place. I fought with it for over an hour trying to use pliers, a wrench and a socket. I eventually managed to get it half way off by wedging the pliers between part of the air filter box and the round nut and pry open the box enough to squeeze the old filter out and put the new one in. It caused the air filter housing to crack just a bit around where the bolt went in as well. I also could not tighten that bolt anymore on that side of the box as it would spin in either direction. Why can't all cars just have the two or three little clamps like on the Firebird I have? It literally takes 10 seconds in that car. My hands are still hurting from that nonsense. Such a horribly designed air filter bolt setup... ugh.
