Hello all -
I'm changing out the rear diff fluid in my '97 Mazda MPV 2WD, and manual transaxle fluid in my '09 Mazda 5.
The MPV specs GL-5 80W if temperature will be < 0 F (-18 C), and 90 otherwise. Not wanting to do seasonal changes, I'll picked up some AMSOIL synthetic gear lube in 75W-90, rated GL-5. No controversy there.
The MT fluid for the 5 is a bit trickier. I would like to use the same fluid but understand that the GL-5 should not be used in an MT rated for GL-4; apparently some of the GL-5 additives can damage the yellow-metal synchro gears.
The owner's manual for the 5 states that GL-4 or GL-5 is acceptable. 75W-90 is recommended for year around use, and 80W-90 for temperatures > 50 F (10 C). So far so good ...
However, the factory service manual for the 5 has a range of VIN numbers for which GL-4 or GL-5 can be used, and a range for which only the GL-4 can be used. My vehicle's VIN indicates that GL-4 or GL-5 will be OK. Interestingly, the higher VIN range is for GL-4 only.
1st question: Would it be better to go with a GL-4 fluid to be absolutely safe?
2nd question: I notice that AMSOIL does make a dedicated GL-4 MTF in 75W-90. Would this be a better choice than the GL-5 general purpose 75W-90 gear lube in a manual transaxle?
Bear in mind MTF is hard to find up here. If I'd seen it in the shop where I bought the gear lube, I would have chosen it for the MTF instead.
Thanks in advance for your feedback!
