You would be happier finding an Aggressive External Tooth Lock Washer.
They have various styles, including Internal Tooth.
If a Split Lock washer is correctly made with proper materials (not Chinesium) the do work really well but IIRC they require a Flat Washer under them as well.
I only see them used as a stand-alone washer in instances where they interface with a hard plastic.
But, even then, I spot them with a Copper Flat Washer under them very often.
If they are used for an anti-vibration purpose there are Anti-Vibration screws as well, where you can skip the split lock.
They have a bit of a Flange built into them, and under the Flange it is serrated to help keep the screw from loosening.
