Last year I bought a used Nissan 9.9 two stroke outboard. It was made in 1998. I used it once as I only planned on using it for lakes with 10 hp limits. Normally I use my Evinrude 15 hp.
I just changed the gear lube and it was milky. I am hoping water mixed in only due to bad washers on the drain and fill screws of the lower unit.
Does anyone have experience with these motors that can give me some insight as to other possible explanations?
By the way, the one time I used the motor it ran great.
Thanks.
Thanks.
