Originally Posted By: dlundblad
Assuming the fluid only flows when the car is in drive, perhaps drive it how I suggested and pull over somewhere and check the temperature ASAP? Immediately put it into park to keep it from cooling down.
You shouldn't have any moisture in your transmission whatsoever. Water is a byproduct of combustion.
Changes in atmospheric pressure from the normal changes in the atmosphere, and from the vehicle going up and down hills causes some air to move in and out of the air space in the trany. That air has some moisture in it, and some of that moisture condenses out as water, that is absorbed into the trany fluid. If the trany fluid ability to hold the moisture in suspension is exceeded some of that water will be present as water not in suspension with the trany fluid. That water can cause parts to rust.
