Originally Posted By: AMC
Almost any lubricant that can provide some friction reduction and handle the high heat and pressure that the ar-15 BCG takes will work.
I agree with the others that say motor oil is a marginal gun lube. If you are going to use a motor oil, I prefer a thicker, heavier oil that stays in place. 15w-40 or 20w-50 HDEO is preferred for thickness and better additive package compared to a normal automotive oil.
My favorite lube is corrosionX. It clings well, reduces friction, lasts a long time, is an excellent rust preventer and can be used to clean. It is basically non toxic, has a very mild odor and is cheaper than a lot of gun specific lubricants out there. I highly recommend corrosionX!
I found Corrosion X on Amazon for $20 for 16 fluid oz shipped, making it $152 a gallon.
Royco 308 (thin, light, creepy oil made for guns) is about $45 a gallon shipped from here:
http://www.skygeek.com/anderol-308-1gl-royco-308ca-preservative-oil-gal.htm
BSW
BSW
