Just got my first Blackstone lab report on my wife's 2013 Mazda 6 with the 2.5 liter non sky active engine.
Oil used Royal Purple HPS 5w-20
Total miles: 27,716
Miles on Oil: 7,716
Make up Oil: 0
Aluminum 5
Chromium 0
Iron 12
Copper 4
Lead 0
Tin 1
Molybdenum 109
Nickel 1
Manganese 1
Silver 0
Titanium 3
Potassium 4
Boron 10
Silicon 9
Sodium 360
Calcium 3242
Magnesium 13
Phosphorus 1177
Zinc 1408
Barium 0
SUS Viscosity @ 210F 56.2 Value should be 46-59
cSI Viscosity @ 100C 9.11 Value should be 6.0-10.2
Flashpoint in F 385 should be >355
Fuel% Antifreeze% 0
Water% 0
Insolubles% 0.3 Should be TBN 5.1 Should be >1.0
Comments: This is an excellent first report for your Mazda. Universal averages show typical wear levels for this engine after about 6,000 miles on the oil. You went a bit past that point, but the engine didn't notice. The viscosity is fine for 5w-20 and the TBN is 5.1 showing active additive remaining for a longer run. Low insoluble and silicon show fine oil and air filtration. Try 10,000 miles on the next oil.
Oil filter used was a Royal Purple oil filter, the air filter was the factory original as Mazda says to change it at 30,000. I changed it at this oil change but if could have made it to 30,000.
Total miles: 27,716
Miles on Oil: 7,716
Make up Oil: 0
Aluminum 5
Chromium 0
Iron 12
Copper 4
Lead 0
Tin 1
Molybdenum 109
Nickel 1
Manganese 1
Silver 0
Titanium 3
Potassium 4
Boron 10
Silicon 9
Sodium 360
Calcium 3242
Magnesium 13
Phosphorus 1177
Zinc 1408
Barium 0
Fuel% Antifreeze% 0
Water% 0
