Wife's car failed inspection for rear wheel bearings. Known problem in these cars (2005 Hyundai XG350) so I went ahead and changed them out myself. Ever since there has been a rhythmic, hollow scraping noise in the rear on both sides. Sounds like a rock stuck in the dust shield but not nearly as loud. Noise is worst at around 35-45 MPH. Above 45 I can't hear it at all. Can't hear it with the rear of the car jacked up spinning the wheels by hand or with the wheels off spinning the rotors by hand.
Things I've tried:
- Adjusted parking brakes (tiny drum brakes on both sides) several times. Never made a difference. Light application of parking brake doesn't change the noise while driving.
- Took a wire wheel to inside of rotors to remove rust/corrosion. No difference.
- Bent dust shield away from rotors. No difference.
- Calipers are fine / not seized.
The only thing I "changed" when I did this job was drill the heads off of the screws that held the rotors to the old hubs, and did NOT replace those screws when I installed the new hubs. I'd be surprised if that's what was causing this.
All I can come up with is that the "face" of the new hub (where the wheel studs go through the rotor) is ever so slightly narrower such that the rotor sits just close enough to the parking brake hardware to rub one of the parking brake shoes or the metal lip on the side of the backing plate.
The problem with my theory is that I can't find any signs of this happening -- there aren't any spots where there's obvious metal to metal contact happening. The noise isn't loud by any means but it wasn't there before.
Things I've tried:
