used_Oil,
yep...the "zero wear" approach to plain bearings is full blown hydrodynamic lubrication...that's where my comfort zone resides, having been responsible for $B of equipment that wasn't going to be inspected for anything less than 30,000 hours in service, and was supposed to last 300,000 hours.
A consumer appliance (which a car is), involves rational compromises in extended life durability...another couple hundred gallons of fuel over the life of a car which is more likely to be rusted, wrecked, or tossed out costs the consumer $500-$1000, regardless of whether CAFE are in the mix or not.
It's rational design.
What gets me bent is the statements made that these oils are for improved durability, they work in this engine, so you should run your 3.8 on 2.6HTHS...and blanket statements that boundary isn't happening more in more modern engines.
So I keep looking at what information is out there, and cling to the gems that the likes of Solarent, Molakule, BobbyDavro, and Bruce 381 drop from time to time, and watch AZSynthetic's low vis extended OCI posts...sent one of my lower hose thermostats to Gary Allen, so he could control yet another parameter on his 0W10 jeep engine.
