I just got back my Blackstone lab report on my 2014 Ram 1500 with the Pentastar V-6 engine.
Vehicle: 2014 Ram 1500
Transmission: 8 speed automatic
Rear End: 3.55 anti-spin
Engine: Pentastar 3.6 liter V-6
Oil: Red Line 5w-20 synthetic
Oil Filter: Mopar MO-349 cartridge style filter
Miles on engine: 6,270
Miles on Oil: 4,902
Make up Oil: 0
Comments: This is a really good first report for your Ram. About 25% of the silicon in this sample is from the Red Line oil, and residual sealers from the wear-in account for the rest of the elevated level in this report. Wear-in also accounts for the higher iron and copper, and you should start to see these elements improve over the next few oil changes, although copper can take a long time to read close to universal averages. That column shows typical wear for this type of engine after an oil run of about 7,100 miles. The TBN was strong, so run close to that interval and check back.
Aluminum 4 Universal Averages 4
Chromium 1 Universal Averages 1
Iron 45 Universal Averages 22
Copper 193 Universal Averages 41
Lead 1 Universal Averages 0
Tin 0 Universal Averages 0
Molybdenum 463 Universal Averages 75
Nickel 1 Universal Averages 1
Manganese 11 Universal Averages 5
Silver 0 Universal Averages 0
Titanium 0 Universal Averages 3
Potassium 7 Universal Averages 3
Boron 52 Universal Averages 42
Silicon 42 Universal Averages 12
Sodium 12 Universal Averages 66
Calcium 2838 Universal Averages 2173
Magnesium 8 Universal Averages 194
Phosphorus 1049 Universal Averages 853
Zinc 1027 Universal Averages 805
Barium 0 Universal Averages 0
SUS Viscosity @ 210F 52.5 Values Should Be 52-62
cSt Viscosity @ 100C 8.02 Values Should Be 7.9-11.1
Flashpoint in F 430 Values Should Be >385
Fuel%
Antifreeze% 0.0 Values Should Be 0.0
Water 0.0 Values Should Be
Insolubles% TR Values Should Be
TBN 5.4 Values Should Be >1.0
Miles on Oil: 4,902
Make up Oil: 0
Fuel%
