I don't know what kinds of compounds are used as a buffer in motor oil (amines?) for TBN retention, but whatever they are I bet the oil would perform identically in the wear test with or without the additive. Much like if you tested an SA oil. It would be easy to test, just take a sample and titrate it until the sample no longer neutralizes the acid, then test the oil in the apparatus.
Do gear oils even worry about TBN? I wouldn't think they do, and I bet they perform well in this test. That alone would prove that TBN retention additives (whatever they are) play no meaningful role in the wear test.
