My girlfriend has a 52" Scag with a 23 HP Kohler Command engine that shut off during mowing and now won't run. The engine will start fine but then dies after about two seconds of running.
I disconnected the fuel line at the carburetor and cranked the engine, and fuel spurts out fine. The spark plugs look okay, and the throttle & choke plates operate. I suspect a clog in the carburetor, but don't know if there might be some electrical issue such as a faulty solenoid. Any ideas as to what could be causing this and how to fix it?
Tom NJ
Tom NJ
